Sporadic Performance Issues
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Sporadic Performance Issues
04-08-2019 11:11 AM
The last few days I've been experiencing intermittent performance issues. Every few page loads one will hang for several seconds (10-20) or indefinitely, then it will be fine again.
I've tried the usual router reboot, and wired connection (rather than wifi) but no difference.
@Gandalf - is there anything you can look at to see if there is an issue?
Many thanks!
David
Fixed! Go to the fix.
05-08-2019 9:02 AM
Hi David
Our tests aren't showing any issues with your FTTP service. Is your wired connection a laptop/computer connected directly into your router using an ethernet cable without any switches or powerline adapters in place?
Do you also have a different router you can try?
09-08-2019 9:21 AM
Hi @Gandalf ,
Thanks for looking in to this... whatever it was seems to have healed - it's not done it for a few days now.
Good to know the FTTP service is OK from your end though.
Many thanks,
David
09-08-2019 10:34 AM
- Full Fibre
