Speeds lower than normal for several weeks
Fixes: 334
Re: Speeds lower than normal for several weeks
@Baldrick1 OK - I admit to not always understanding those log reports, even after all this time. Embarrassed
TheMightyAJ
Fixes: 126
Hi @spinvector,
I'm sorry to see that the speed has dropped off a bit recently. I've had a look over the account this evening and whilst line tests aren't showing any underlying faults on the line, I have made a slight adjustment to the profile on your account, which may have been causing the issue. If you reboot your router in about an hours time, we should see if this change has made any difference to your speeds. Please let us know if the speeds improve at all and we'll pick this back up for review tomorrow Smiley
 Alex H
spinvector
Hi @TheMightyAJ , thanks for that. I've rebooted the router and I'm now seeing around 33 Mbps on the speedtest via ethernet, which is slightly better than I was getting at the top of this thread, but not as close to 40 as I used to get. I'm wondering if it had anything to do with the recent firmware update.
Fixes: 1,642
Thanks for getting back to us @spinvector
I'm sorry to see your speeds are lower than where they used to be. I've tested your line today and the tests are showing your router's getting the full 40mbps download and 10mbps upload with the profile our side at the highest of 37mbps.
Looks like you've always had a static IP so I don't think the problem's due to the profile we hold on your account, plus the IP profile of the line will be about that, as that usually sits a few megabit below the sync speed.
When you ran the speed test, was that with your computer plugged straight into your router with no powerline adapters or switches in place? Also were all other devices switched off and nothing else open on your computer?
spinvector
Hi @Gandalf  - sorry for the delay getting back to you. Yes, I tested with the computer plugged directly into the router (which connects to the master socket via a mk3 faceplate). I repeated the test making sure all other devices were off or in airplane mode on a freshly booted linux box with no other applications running and the best I get is 34.2Mbps (and pretty much the same via wifi), which I guess is OK.
In fact I just tried an actual file download and got a reported 4.2 MBps (as opposed to the <3MBps I had for the past few weeks), which is what I'm used to seeing, so I think things are now back to normal. Thanks for your help, and also to @jab1@Baldrick1 , @TheMightyAJ
Fixes: 1,642
No problem, I'm glad to see you're speed is back to normal now. ‌Thumbs_Up‌Let us know if you have further issues or there's anything else you'd need help with.
