Speed Reduction since renewing contract.
dougjbarnes1
Before my previous contract was up for renewal, I ran a series of speed checks and was getting about 31 M download speeds
Since renewing my contract I find that the speed has dropped to about 28MB, i.e a 12% decrease.
Can anyone make any suggestions why, I've tested both via WiFi and via a direct wired ethernet cable, getting the more or less the same results regardless of connection.
5 REPLIES 5
Fixes: 387
Re: Speed Reduction since renewing contract.
@dougjbarnes1 I can see your speed does appear to have reduced, but I would not say it is necessarily due to your contract renewal that has caused it, in fact, I would say it is more of a coincidence.
To examine the situation further, could you post (1) the result of BT Broadband , ensuring your phone number is not showing on the screenshot. (2) the result of the 'Advanced Diagnostics' from BTW Performance Tester , and (3) the 'Help Desk' tab from your Hub, redacting any personal information.
I don't think this will show a problem, but suggest you also do a Quiet Line Test -17070, option 2. After your number is confirmed, all you should hear is the regular 'Quiet Line Test' announcement.
adam945
Fixes: 113
Good morning @dougjbarnes1
Thanks a lot for reaching out. Where are you finding your speed test information? If you're getting it from your online Member Centre, you'll find that these value have decreased recently, as we've changed the way in which expected and minimum speeds are calculated. I've just run a broadband test though and can see that the line is syncing at 31.0 Mbps.
As per @jab1 's post, a screenshot of your helpdesk page on your Plusnet Hub One would go a long way here, in my opinion its the way that customers can check out their sync speed. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 31.0 Mbps
Upstream Speed 8.5 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 821.4
Upstream Rate Assessment Good
Downstream Rate Assessment Reasonable
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-32.4M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-11-04T10:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 32.3 Mbps 32.3 Mbps 32.3 Mbps
Up Stream Line Rate 8.2 Mbps 8.4 Mbps 8.4 Mbps
Up Time 862.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 1.0 0.0
 Adam
 Plusnet Help Team - Leeds
Mustrum
Fixes: 81
@adam945  perhaps you missed this bit:
RealAleMadrid
Fixes: 68
@adam945  As @Mustrum  has spotted the line is on a banded profile, confirmed by the Downstream line rates in the GEA test.
Because the line is on retransmission high the Downstream speed of 31Mbs shown near the top of the test is not the true modem sync speed but reduced to about 95% and incorrect.
adam945
Fixes: 113
Argh, shoot, thanks a lot for spotting that. Apologies!
I've now raised a DLM reset, so hopefully this should be sorted within the next three working days. Smiley
 Adam
