Solid red light on PON
portalfeline
HI,
As of last night the red light has been solid on the box for PON. So no interenet.
Have done the whole turn off and on in hopes of that working and nothing.
I have also texted the help number but for some reason that isn't working as it is not recognising my mobile number (which is attached to my account) and I do not have a landline number and I am not able to to do a phone call as of now.
Some help would be much appreciated.
7 REPLIES 7
Fixes: 382
Re: Solid red light on PON
Welcome to the forums, @portalfeline . The fact you have a red PON light indicates there is a fault in the OpenReach network.
Unfortunately, the BOT does not recognise mobile numbers as a connection if you have FTTP - all you can  do (at the moment) , is call Plusnet and report the issue.
willcutforth
Fixes: 113
@portalfeline We need to book an appointment. When would you be free? The slots are 8-1 or 1-6
 Will Cutforth
portalfeline
HI,
Thank you, any time is good for me.
MatthewWheeler
Fixes: 503
Hi @portalfeline
Looks like things are back up and running now
Let us know if you have any further issues
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
adamchurchman12
I now have the same issue, a solid red PON light.
I have also tried turning it off and on and checking the wires are properly connected.
Not sure what to do now other than call.
Any other help would be appreciated.
Fixes: 382
Calling in is your only option, @adamchurchman12 , I'm afraid.
For any others with this issue - your only option IS to ring Customer Support - this is a failure in the Openreach network.
willcutforth
Fixes: 113
I have tested the line and they want to book an engineer @adamchurchman12 please let us know when you would be free?
 Will Cutforth
