Slow evening speeds
libbyf
Slow evening speeds
I've raised a ticket for this (137213975) but thought I'd post here too, to make sure it get seen by the correct members of staff. Wink
My speeds are slowing every evening, and have been for most of the month. Stats from my Sam Knows logging attached.
12 REPLIES 12
HarryB
Fixes: 256
Re: Slow evening speeds
I've made sure that ticket has been moved to the correct pool for you, to ensure it's seen by the appropriate team.
 Harry Beesley
libbyf
I was asked to run the BT speedtest but the second part of it doesn't work. Is that because I'm on FTTP?
SpendLessTime
Fixes: 86
You need Plusnet to give you the "Broadband circuit Service ID" as that is the only way I can get the further diags to run on FTTP. You just complete that 1 field (ignore the rest) .
libbyf
Thanks. I'll ask for that on my ticket. Smiley
HarryB
Fixes: 256
I've put that on the ticket for you Smiley
 Harry Beesley
libbyf
Ta! Won't be about this evening (fireworks and all) but I'll try the test again in the evening tomorrow.
libbyf
Posted speed test results on Sunday evening. How long does it normally take for an update? Smiley
HarryB
Fixes: 256
I'd hope you'd be getting a response at some point today.
 Harry Beesley
libbyf
Just had a phonecall - I'm being moved to a less overloaded port in the exchange.
MatthewWheeler
Fixes: 480
Let us know if that doesn't sort it.
 Matthew Wheeler
libbyf
HarryB
Fixes: 256
Glad to hear that seems to be sorted now. Thanks for letting us know Thumbs_Up
 Harry Beesley
