Slow download speed
FuzzyB
Slow download speed
I cannot get anything faster than 18mps for downloading files, I don't understand why this is, does anyone have any ideas why this is the case?
This is the service I pay for
  • Product:  Full Fibre 145
  • Estimated Download Range:  145 - 160Mbps
  • Estimated Upload Range:  27 - 30Mbps
  • Minimum Guaranteed Speed:  80Mbps
  • Current Line Speed (Download):  160Mbps
4 REPLIES 4
FuzzyB
Re: Slow download speed
An update...
Called support, no issues on the fibre link
reset router and set up again
tested speedtest shows full speed
I should add that I get 18mps download speeds on wifi as well as CAT6 ethernet on the same pc.
downloaded a game from the Epic store 18mps, downloaded a game from Steam 18mps, downloaded from usenet 18mps
Could this be an issue with Openreach?  I reset their FTTP box before resetting the router but its made no difference.
I'm at a complete loss as to why this is happening.
Browni
Aspiring Hero
Fixes: 60
It's down to how the speeds are being reported.
18MBps = 144Mbps.
Notice the capital 'B' and the lower case 'b' ?
FuzzyB
That makes sense when you convert the megabytes to megabits, having just read an article on that very subject. Thanks for the response.
Browni
Aspiring Hero
Fixes: 60
You're welcome.
