Slow connection speed
thescarer
I have noticed my internet being sluggish over the last few days. When tested it says I'm recieving 17-19 Mbps instead of the usual 30-35 Mbps. I've tested with pc and Xbox, with both showing the lower figure. Everything is hard wired, and has been power cycled.
Any help appreciated.
4 REPLIES 4
Fixes: 1,495
Re: Slow connection speed
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
TheMightyAJ
Fixes: 126
Hi @thescarer,
I'm sorry to hear that you're experiencing issues with the speeds. Do you know if the router is connected to the master phone socket in the property? Please could you try setting it up within the test socket, if you haven't already done so? For reference, we have a guide on how to do this here. I've tested the line this afternoon and our tests aren't picking up any faults, with the downstream sync speed currently listed as 40Mbps. It may be worth trying another Ethernet cable, if you've used the same one on both devices when carrying out these tests.
 Alex H
thescarer
I'm still getting low speeds when testing, 20 Mbps down, 4-9 up, (up varying wildly). Also tonight I've been experiencing rubber banding while gaming. All new cables and router connected to test socket make no difference so it's router/modem/line.
LaurenB
Fixes: 131
Hiya @thescarer,I am sorry that the issues are ongoing.
As the issue is impacting wired connections and the troubleshooting hasn't helped, I would advise to log a fault with us here:  https://faults.plus.net so we can get that progressed for you as testing is not highlighting what may be causing this.
 Lauren Barry
