Slow Speeds
- Full Fibre
- Slow Speeds
Slow Speeds
03-01-2012 10:01 PM
My speed's have slowed down badly! I have registered for the 80/20 trial's but have yet got no response. Can any PN staff shed any light on my plight?
Re: Slow Speeds
03-01-2012 10:10 PM
What are your BT speedtest results and what results do you get from other speedtesters? Without this we have nothing to go on.
Re: Slow Speeds
03-01-2012 10:17 PM
Re: Slow Speeds
04-01-2012 12:10 AM
Quote from: Peter There is no 80/20 trial yet or any word to say there actually will be one from BT or Plusnet. There is also no registration for it either... the thread you may be referring to where you put your name down was started by a forum member, not plusnet, after a query about the possibility of BT doing trials of the faster FTTC connections.
Firstly, there clearly is an 80/20 trial from BT as numerous ISPs are talking about it (see http://www.idnetters.co.uk/forums/index.php?topic=27470.0).
Secondly, you clearly haven't read the thread you're claiming authority on, as this post by Dave is quite clear on the subject: http://community.plus.net/forum/index.php/topic,98623.msg856203.html#msg856203
I don't know the reason for LittleOtik deciding to leave Plusnet, but your reply hardly helped.
Re: Slow Speeds
04-01-2012 12:20 AM
Re: Slow Speeds
04-01-2012 8:03 PM
Re: Slow Speeds
04-01-2012 8:35 PM
Re: Slow Speeds
05-01-2012 12:06 AM
Re: Slow Speeds
05-01-2012 12:17 AM
I'm wondering what this could be. Have you tried raising a fault? If you want to, PM me your username and I'll take a look tomorrow.
Re: Slow Speeds
05-01-2012 1:09 AM
Re: Slow Speeds
05-01-2012 11:27 AM
Can you post your BT speed test result here. Also, could you run one connected directly to your modem?
Jojo
Re: Slow Speeds
05-01-2012 11:42 AM
Your line sync rate is 40Mbps downstream and your line speed profile is also set correctly on our network layer. We really need the BT speed tester results to progress further on this one. Just run through the test at:
http://www.speedtester.bt.com/
And post the results here and we'll be able to investigate.
Re: Slow Speeds
17-01-2012 1:22 PM
