Slow Ethernet Speed - Fast Wifi Speed
PeterStocks
Hi All
Im hoping someone can help as im not getting any joy from Plusnet support
Switched over to Full Fibre a few weeks ago. Everything seems fine but Im getting slower ethernet connected speed than I am Wifi. Its normally the other way around.
Ive left it a few weeks for things to settle as they normally suggest but nothing has changed
Im getting around 90mbps on Ethernet and 140-150 on wifi
Ive re-booted the router ( Hub2) and have changed my ethernet cables.
Ive tried my MacBook and my work laptop to do the tests. Both are the same.
Does anyone have any idea what might be causing this ?
32 REPLIES 32
Fixes: 388
Re: Slow Ethernet Speed - Fast Wifi Speed
@PeterStocks My thought is the Ethernet card in your machines, but I could be wrong.
Browni
Aspiring Hero
Fixes: 61
or the ethernet cable which needs to be cat5e or better.
PeterStocks
The new cables Ive bought are Cat5e
Fixes: 388
Good call, @Browni , and probably the right one.
Fixes: 388
Then it sounds like the card, as I said - how old are the machines in question?
PeterStocks
My MacBook is 5-6 years old the work laptop Im not sure. Probably the same
Fixes: 388
Can you find the specs of the card in each, I'm guessing they aren't Gbit?
PeterStocks
this is the spec for the Mac
Fixes: 388
That looks as though it should be doing better than it is, but I am not a hardware expert.
Fixes: 585
The hub 2 will show the link speed for wired devices, IIRC  both on the device list and in the event log
PeterStocks
I’m not sure how to do that. I’ve accessed the hub but cannot see any link speeds ?
@PeterStocks
unfortunately I do not think the My Devices shows the link speed.
However if you navigate from the home page to Advanced Settings >Technical Log >Event Log, hopefully you will see this line
Wire Lan Port N up, Speed 1000 Mbps where N is 1,2 or 3
This message appears when the device connects to the LAN.
If you laptop is connected to a device like a switch or powerline device which runs at 100Mbs then the laptop speed  will be limited by that device.
HTH
Fixes: 585
I don't have my hub 2 running at the moment to check. I thought it showed link speed on the devices page.
It certainly logs the speed of each connected port in the eventblog when a port connects. So iunplug and reconnect the device and then check the log
PeterStocks
So im directly connected to the Hub and this is what the report is showing
Wire Lan Port 1 up, Speed 100 Mbps
Would this suggest that the Hub is limiting the speed ?
