Safeguarding static IP during upgrade from FTTC
Fixes: 580
Re: Safeguarding static IP during upgrade from FTTC
Now I'm just hoping and praying for ducting! We're in a relatively new build (2011) with underground line and block paving over the top. Fingers crossed for a straightforward job.
@BarnsleyChop what does the BTwholesale checker say for your address, particularly the 'Install process' column for FTTP and the narrative below the availability table ?
BarnsleyChop
@MisterW it shows 'available' and the install process is '1 stage.'
The narrative says, 'Single dwelling unit residental UG congested duct'
The word 'duct' is reassuring, 'congested' not so much. If they can make it to the doorstep without digging then the rest couldn't be easier. The grey trunking on the wall connects straight through the wall into our internal garage and that's where the old modem is situated.
OR already texted confirming the install appt. so it looks promising so far!
Fixes: 580
@BarnsleyChop the '1 stage' means that they (Openreach) expect to complete the install in one visit.
The 'congested duct' is not good, the fact that it actually says that means that they checked when installing the infrastructure and discovered it blocked! If they cant pull the fibre through on install day,  they may need to request a dig team to replace the duct, which will delay the install!
Do you want the ONT in the same place ?
Fixes: 117
@BarnsleyChop
While it didn't say "blocked" I suspect they tried to rod the duct to leave a draw rope in place and found it "congested" It would not have been in their workscope to try and force the issue in case of damaging existing cables. That, and as explained to me when my network was being installed, it doesn't become a problem until a customer places an order.
You will only find out on the day if there is an issue.
There is a certain lee way as to where the ONT goes if you want to change location. Remember also the router connects via ethernet cable so doesn't have to be in the same location.
BarnsleyChop
@MisterW thanks for the heads-up!
I'm worried about what will happen if they decide they need to dig up the street outside our house, because it's block paved and wouldn't be cheap or easy to make good. Would be gutted if they were to turn around and say we can't have it.
Yeah the ONT in the garage works fine for me. I've got my own switch, firewall and home network to take over from there.
Fixes: 580
That's very unlikely. The worst case is that the install may be delayed due to needing to dig to replace the duct.
BarnsleyChop
OK, thanks, that's reassuring.
I've waited long years for availability of any full fibre service (we've never had access to Virgin) so a delay isn't a problem for me, as long as they bring it in the end!
It's the extra UL bandwidth that I really crave - just another 10-20Mbps would make a world of difference when dialled in through my road warrior VPN.
mystreet1
Seasoned Pro
Fixes: 7
If you are 'handy' have a look at the ducting and see if you can see if there is any movement in the existing cable going through the ducting.
Friend requested Full fibre but their existing ISP said no way, blocked ducting, we gave a look and could easily see that the existing cable was free and moving at both ends. They placed an order with PlusNet and 2 weeks later had FTTP up and running.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
BarnsleyChop
@mystreet1 to be fair to them, there's been no opposition at all with regards to the congested duct issue and nobody has even mentioned it. PN booked the appointment without hesitation and OR confirmed within the hour, so someone should definitely be coming to have a go at it.
I served my time as an electrician so I do have some relevant experience, but it's not my business to tell them how to do their job. When the day comes I'll be watching from a respectful distance and trying my best to be helpful without interferring. Smiley
Fixes: 117
@BarnsleyChop
I suspect it's not a major problem because if it was then it would have been flagged KCI2 which usually requires a survey prior to install.
If they had to, I suspect the coud try to pull the fibre through using the existing copper wire as the "pull" rope. Remove and replace to get past the congestion. Mind you if this failed then you'd lose your current connection.
Do let us know how it goes on the day.
BarnsleyChop
@bmc yeah that would be my approach, but I would pull the copper back away from my house first with a draw wire attached, leaving myself the option to abort and pull the copper back in if it went tight. Even then, it's still a point of no return once the copper is all the way out back to the inspection point. I'm sure whoever comes will have the experience to judge how far they can push it without too much risk - these guys are doing the task day in, day out.
BarnsleyChop
Hi all,
Just following up for those who asked me to: The install was successfully done today! Info re the 'congested' duct turned out to be accurate, either due to debris or misaligned joints. Either way, the draw rod wouldn't go down and the guys had to go for a 'cut & pull,' after warning me that I would be left without service should the join between the old and new cables break off midway. I'm pleased to say the fibre actually came through easily using the old copper cable to draw it.
Very satisfied with the substantial improvement in bandwidth (pulling roughly 450-470Mbps down and 71-73 up on the 500 tier product) and no issues with the IP address or anything else; all I did was take the WAN interface down before install and bring it back afterwards.
I've now got my ATA setup ready to join A&A: Just waiting for official confirmation of the product change from PN before I ask A&A to port my number in. I'm hoping that process will be as straightforward as the broadband side, having done some homework to get the ATA setup correctly behind the firewall, with the appropriate ports opened etc etc.
Thanks again for the advice & encouragement given last month.
Fixes: 580
There should be no reason to open/forward any ports. Just make sure that 'sip keep alive' is set on your ATA.
BarnsleyChop
Thanks for that @MisterW, I've followed A&A recommendations for now but I will try to lock it down more once I've got it working. I think the keepalive is on by default so it ought to be OK.
The ports (SIP & RTP) are only forwarded to the ATA and I've got it on an isolated LAN (physically different NIC) to mitigate the risks. No web or remote access ports open, of course. I've also set static ports on the outgoing side, no PAT.
Fixes: 117
@BarnsleyChop
Good to hear things went well.
