Safeguarding not working
PGoodchild66
Hi I've just joined and turn on the safeguarding feature and despite saying it is turned on is not working. Its not blocking sites it should be and after turning it on and off its still not working. I read it had been an issue in the past, can this be looked at and fixed ASAP please.
4 REPLIES 4
Fixes: 583
Re: Safeguarding not working
@PGoodchild66 have you restarted the router since you turned Safeguard on ?
PGoodchild66
I have but still not working
Fixes: 583
I've never used it myself but I understand it can take a couple of hours to start working. If its not working by  tomorrow,  I suggest calling customer services
PGoodchild66
thank you will do
