Router upgrade
- Full Fibre
- Router upgrade
Router upgrade
23-02-2011 11:50 AM
Also, I spoke to Novatech to see what they stock, but when I stated I needed a "cable" router (as was stated on the Netgear box), the salesman was unsure what I meant and asked if it was DSL or ADSL. What should I be looking for?
Re: Router upgrade
23-02-2011 12:01 PM
you beat me to the exact same question. i have been investigating which router is supplied for this trial, which seems to be the unit you have been supplied.
i too would like a gigabit based network, and wasnt too sure about the situation as my new plusnet account i am having activated is "non contract" (i.e. supply own routers) but it looks as though plusnet provide a router in any case (guessing due to the "trial" part of it?)
i had previously looked at the following 2 routers:
Linksys E3000
Netgear WNDR3700 (v2)
i think the primary feature that is required is ethernet-based WAN port and support for PPPoE (wasnt too sure of this need myself, as thought it may be a straight pass-through connection up to the BT-supplied VDSL? maybe someone can comment who has proper knowledge, than my double guessing?!)
the above routers i list have both, are decently spec'd (i.e. for running DD-WRT custom firmwares if so desired) and score very highly on the smallnetbuilder.com which i regularly use as a reliable source of info.
so the question is can it be confirmed these are acceptable routers for use with the FTTC trial, hooking into the BT-supplied VDSL?
thanks
jingomandan
Re: Router upgrade
23-02-2011 12:14 PM
Without wishing to stray off track too far, as this a fibre forum, I have a techie friend who has queried why I am doing this. He reckons if I connect a gigabit switch to the current 10/100 router, and then feed all Pcs, printers, extenders, etc through the switch and not the router, then there is no need to upgrade the router. I mentioned this to Novatech and they said this is wrong and the router will slow the LAN speed, even though the switch is downstream. My techie friend is certain Novatech are wrong.
Any ideas? Do I need to change the router?
Re: Router upgrade
23-02-2011 12:36 PM
Quote from: oakwoods the standard Netgear WNR1000 but this is only 10/100 and I need to stream HD with a gigabit LAN.
Why?
Re: Router upgrade
23-02-2011 12:47 PM
Re: Router upgrade
23-02-2011 12:50 PM
it'll get confusing and may not always guarantee it will all run at gigabit, but i would concur with your techie friend in principle. direct ip to ip comm's should occur at gigabit speeds through the switch, not even bother with the router.
HD will stream across megabit (10/100 LANs) no problem too. atleast on wired connections. likely requires 50Mbps (note the lower case "b" to signify megabit, not megabyte) for blu-ray quality m2ts files (currently the highest available). it will put you LAN at a higher utilised bandwidth, but should handle this, so bear in mind.
it is a bit more than i have paid also, but these are top end consumer routers. about as future proofed as you can get currently. they contain multiple radio's across dual-bands so the hardware performance should be the best available, i.e. strongest wifi signal with most channels, best LAN-to-WAN throughputs onto the speedier fibre broadband speeds, etc. the extra grunt allows for DD-WRT which i am serisously considering to eek out the best performance of the routers from software/firmware perspective (rather than simply relying on stock firmwares of the manufacturers). though there is also an equal argument that for your bog standard wifi router, why would the average joe need these additional features? general geekery is likely the best answer
there will also be gigabit-based routers that are less well spec'ed but above the WNR1000... something like the Linksys E1000 or E2000, and likely half the price. not sure of equivalent netgear models. D-Link are also a reliable brand in this field.
have a hunt around smallnetbuilder. for example, nice article concerning different linksys routers (and how they are just re-badged linksys WRT models) is here:
http://www.smallnetbuilder.com/wireless/wireless-features/31111-inside-story-linksys-e-series-and-ci...
i will be putting on a NAS-based QNAP (or similar) device which will provide many of my internal network functions, and this will require gigabit link to my pc's/laptops. and in your setup, if these were set across the gigabit switch most things should occur at the higher internal speeds.
Re: Router upgrade
23-02-2011 1:44 PM
It appears Novatech are correct and my friend is wrong. I have just wired in a gigabit switch. Cable from router to switch. Cable from PC to switch. Cable from extender to switch. The PC to extender line tested at 22Mbps, same as before. Double checked with an HD video and confirmed it is still unplayable. So it seems Novatech are correct when they state the router is killing it.
Looks like a new router is needed. I will have a look at the Linksys and Netgear models you recommended. Thanks for your help. It's much appreciated.
Re: Router upgrade
23-02-2011 1:57 PM
have you tried that pc to extender on the gigabit switch *without the router connected at all*?
Re: Router upgrade
23-02-2011 2:09 PM
Surely the router is still needed for IP addresses. I think what you have suggested would be the same as connecting the extender directly to the Ethernet of the PC. That cannot work, can it (or am I missing something)?
Re: Router upgrade
23-02-2011 2:20 PM
the problem arises if you use any DNS hostname-lookup feature, DHCP scope, or some other config or service like that. you havent said how the extender is accessing, but if its direct (i.e. not via a workgroup or something similar, which will require NetBIOS, etc) should be fine.
Re: Router upgrade
23-02-2011 3:01 PM
I'm surprised I haven't been kicked by a moderator yet for being off topic. Sorry moderators.
Re: Router upgrade
23-02-2011 4:31 PM
Re: Router upgrade
23-02-2011 4:41 PM
If you have two Gigabit devices connected to a Gigabit switch then the data flow between those ports will be Gigabit regardless of other devices connected to the switch.
If the data path is via a slower device then it will be buffered in the switch and fed out at the slower rate on the slower port.
Re: Router upgrade
23-02-2011 5:18 PM
Novatech are stating the data will still pass through the router. He did make a point by stating that if it were possible to connect a gigabit switch and still achieve gigabit speed, then why would they make gigabit routers? A 10/100 router + gigabit switch is cheaper than a gigabit router.
Re: Router upgrade
23-02-2011 5:30 PM
Also, what switch and router are you using?
They make Gigabit routers because the chipsets are cheap enough now and it's a good selling point...
