Router to laptop seems slow
- Full Fibre
- Router to laptop seems slow
20-01-2011 5:09 PM
The router will only connect to my laptop over wireless at 72. I can connect to other routers at 130. How can I up the speed of the plusnet router?
Message 1 of 6
(1,816 Views)
5 REPLIES 5
Re: Router to laptop seems slow
23-01-2011 2:47 PM
The problem is with you WLAN adapter in your laptop. I'm guessing the adapter's a Dell DW1501?! I'd suggest replacing it with an Intel WiFi Link 5300.
Paul
Paul
Message 2 of 6
(349 Views)
24-01-2011 8:29 AM
It is an integrated Intel 4965AGN.
Performance
Up to 5x faster¹
Data rates up to 300Mbps offer major improvement over today's 802.11a/g products that deliver 54Mbps. This helps overcome network capacity issues, allowing increased simultaneous network activity for large file transfers, network backups, streaming video, multi-player gaming, VoIP and more.
I did mention in the original post that I can connect at 130 to another router (BT Home Hub).
Performance
Up to 5x faster¹
Message 3 of 6
(349 Views)
26-01-2011 1:15 PM
Maybe I should rephrase the question. Has anyone achieved more than 72 Mps wireless with the supplied Netgear N150 WNR 1000 V.3 router? If so, did you need to change anything?
I have upgraded to the latest router firmware 1.0.2.26 and wireless card driver Intel 4965AGN 12.4.4.5.
Message 4 of 6
(349 Views)
26-01-2011 9:28 PM
Apologies, that's a nice WLAN card, I bought one for my Sony Vaio machine.
Anyway, the WNR1000 maybe a '150N' router however, you'll typically achieve around half the advertised throughput in use. That seems to fit quite well with the 72Mb/s you're seeing.
Paul
Paul
Message 5 of 6
(349 Views)
26-01-2011 10:23 PM
Would someone from PlusNet care to comment - what wireless connection speed should I expect with the supplied Netgear N150 WNR 1000 V.3 router?
Message 6 of 6
(349 Views)
- Full Fibre
