Router staying orange
Lee83
Internet has been working perfectly untill Today, router went to flashing orange with the bb sign underneath it , tried power cycling ,tried resetting password in both router and account ,still nothing ,help !
18 REPLIES 18
Lee83
Re: Router staying orange
Tried factory resetting aswell ,is there any work in my area ? Any other ideas would be appreciated
Lee83
Anybody ?
Mustrum
Fixes: 81
Does your phone line work?
Have you reported a fault?
Lee83
Phone line works fine ,im going to have to report a fault ,it has been all working perfectly ,untill this morning
Mustrum
Fixes: 81
It could be worth going through the steps in the Help Pages testing from the "hidden" test socket in the Master Socket if you have one, and trying another router if you have one.
Lee83
Its ok looks like a local outage
Fixes: 1,662
Sorry to hear you're having connection problems
From looking at your connection, I can see a couple of drops recently.
Testing your line isn't identifying any Major Service Outages linked to your broadband circuit.
Are you still having problems?
Lee83
Yeah the drop outs were me power cycling the router ,i phoned up and the member of your help team said there a outage in my area ,and having checked the exchange status ,plus net reported Major service loss in my area ,so i and the member of the help team assumed this was the issue
Mustrum
Fixes: 81
Is your router still orange?The chart above only shows a couple of outages so something does not add up?
Lee83
Yes its still orange the drop outs were me power cycling the router , and my exchange is showing major outages in mt area and area code ,so i assumed this is why my router is still orange and wont connect,untill the exchange is sorted?
Mustrum
Fixes: 81
Then the graph that @Gandalf has shown is not your line - apart from the two short drops it is showing you are connected.
Fixes: 1,662
@Lee83
Mind dropping me a PM with your username so I can double check?
Fixes: 1,662
Thanks for your private message @Lee83, it looks like I was on the wrong account. I think your email address registered to your forum account is used by a different account, so I was bringing up that when searching by your email.
This is looking better. I say better, actually worse, but more in line with what you're experiencing.
Testing your line isn't showing any outages associated with your broadband circuit, however the test is failing to complete correctly and I believe you've spoken with one of my colleagues who has raise a fault to our suppliers.
We'll provide an update within 24-72 hours via this ticket
Lee83
@Gandalf ,could you check for me ,that its not any kind of authentication error ,as i have read that these can cause the same problem that im having
