Router reboots every day
- Full Fibre
- Re: Router reboots every day
15-01-2022 8:31 AM
17-01-2022 7:29 AM - edited 17-01-2022 7:30 AM
Thanks for your post @smifo11 welcome to our Community Forums.
I'm sorry to see you're having connection issues.
Looking at a graph of your connection I've attached below, it doesn't look like the broadband signal into your router is dropping frequently. I've also tested your line and that's not showing any issues.
Does the light on the front of your router change colour consistently every morning?
17-01-2022 7:47 AM
17-01-2022 10:33 AM
Hi @smifo11
Is your router plugged into the master telephone socket with no extension cabling between your router and the socket?
Also if you've not done so already, it may be worth plugging your router into the test socket explained Here because this should rule out any internal wiring from affecting your broadband connection as this can cause a connection to drop.
Let me know how it goes.
17-01-2022 11:20 AM
17-01-2022 2:41 PM
Awesome, sounds like a plan. Cheers
- Full Fibre
