Router light blue but no internet
bradhughes
Router is blue, i log into it it says connected etc gives an IP everything but no access, if i use manual details its not longer blue, read on here it needs to be manually activated? can someone help
14 REPLIES 14
Fixes: 334
Re: Router light blue but no internet
Is this a new connection?
bradhughes
yeah new fttp connection clearly activated since it turned blue and gave an ip etc just doesnt connect to actual internet
Fixes: 334
The ONT cable is connected to the red WAN port?
bradhughes
yes of course the router light is blue the status is connected i am being given an IP etc its all working fine but being denied access to the internet like its not been activated on plusnets side or something
Fixes: 334
Exactly what message is displayed when you can't access the internet?
bradhughes
mystreet1
Fixes: 6
silly question because you have properly all ready done it, but have you turned it off and on again?
Was this a new install with an engineer, if yes, they should test that it is working and you can browse pages.
If a 'take over' it may be that OR/BT need to update the records to allow your username access on that 'node'
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
bradhughes
just an activation
Fixes: 1,491
Moderators Note
This topic has been moved from Broadband to  Full Fibre
Fixes: 124
Looking at the Hubs Advanced settings >Broadband, what is the broadband username?
It needs to be your account name as used to login into the members centre in this format youraccountname@plusdsl.net
If it is setup@plus.net that might explain the Blue light and no internet access.
If that doesn't work it could be worth trying a factory reset of the Hub to see if that kicks the connection into life.
Using a paper clip or similar push and hold the reset factory reset button in for around 25 seconds or until the light goes out.
HTH
bradhughes
yeah thats the thing, i clearly have internet coming down my line as it populates the ip etc from the setup username, if i use my own details they dont work as they havent been activated yet it seems so i wondered if someone can do that for me since thats all thats left to be done
bradhughes
even the bt wholesale checker has now been updated to show ONT exists with active service instead of no service so its all on i just dont have access
Fixes: 124
It can take up to midnight for a service to go live, I suspect the IP Address is a place holder used for the setup account rather than a live Public IP
James30
Fixes: 32
@bradhughes Hi, it looks like it's connected now so all is well. Is it working from your side too?
James - Plusnet Sheffield
