Router activation when it arrives early
redmog
There are many messages asking what to do when the router's not arrived by fibre activation date, but what about when it is the other way round?
I was told my fibre upgrade will take effect on 13/10/2017 but router's arrived today, 10/10/2017.  I can't find anything in the correspondence, instruction leaflet or online help to say whether I should instal it now or await a message on 13th.  Can someone pse let me know - and why not make it clear in the upgrade paperwork and emails?
8 REPLIES 8
jaread83
Fixes: 81
Re: Router activation when it arrives early
Hi @redmog, welcome to the forums!
There should be a note on the instructions to NOT install the router until your fibre has been activated. I also received my router a few days before activation and held off as the instructions said it was important to not connect it until everything has been confirmed. It might have something to do with the automatic setting up of your user credentials once connected (I am sure someone else will be able to confirm why).
My advice would be to wait until the fibre has been confirmed and then connect everything up (even as tempting as it is to get it set up!).
redmog
Many thanks for this, jaread83 - I'll take your advice!
jaread83
Fixes: 81
You're very welcome Smiley
drolerif
HI, I have installed mine as i am swithing from adsl2+ from plusnet to fibre, and these hubs are used for both. Works fine for adsl2+, im hoping i dont need to do a reset or something when they switch me to fibre. heres hoping its automatic.
bobpullen
Fixes: 330
It should be fine. There'll be some interruption when the fibre connection renegotiates, but you shouldn't have to reconfigure anything.
redmog
Thanks for this, Dolerif
redmog
Thanks, Bob, that's reassuring
Fixes: 1,649
That's only the case for new activations, as plugging a router in early before an account has been activated can cause problems with the automatic setup process.
A heads up, your fibre service is due to go live on the 18th October. It's been delayed due to engineer availability.
