Restart trial installation on ticket #134765735
ginge6000
I applied for to be on the FTTP trial when it became available over a year ago but due to building work on the house the installation couldn't be done.  The external part of the work is finally complete so please can you re-activate my order - let me know if I need to sign up for the trial again.
Kind regards,
Ben
9 REPLIES 9
Fixes: 1,550
Re: Restart trial installation on ticket #134765735
Hi Ben. We can't re-activate the order I'm afraid but if you can sign up again at trials.plus.net we'll get a new order placed.
Let us know over here once you've done this and we'll pick it up.
ginge6000
Thanks Gandalf.  I've signed up again on ticket #176159747
Fixes: 1,550
Cheers Ben. I've placed the order now and we'll update you again shortly.
ginge6000
Thanks for your help.
Ben
ginge6000
The fibre install was completed yesterday (less than 2 weeks - I wasn't expecting that!!!!).  My download speeds are still 7Mb although the upload is showing the expected 20Mb - is there a switch that needs to be flicked to change my account from an ADSL profile to an FTTP one?
Ben
Aspiring Hero
Fixes: 33
@ginge6000
The answer is yes - FTTP is not integrated into PlusNet back office systems so sometime today (hopefully) an FTTP trained staff member will do the necessary and "flick the switch"
A router re-boot is then required.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Hi there.
Thanks for getting back to us. I've got to make a few changes on our side, I'm doing that now. In doing this, you might get a few odd Emails, don't worry about it, it's all quite normal.
If you reboot your router, you now should now be live on fibre Smiley
Tony
 Tony T
ginge6000
Thanks Tony - running super fast now!
Massive compliments to Plusnet & Openreach for the speed of the install - the engineers did a great job (even if they were rather "chatty")
Ben
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Hi Ben,
I'm pleased that the install ride was so smooth and that fibre speeds are now correct. Enjoy!
Tony
 Tony T
