Problems with WNR1000 Router
- Full Fibre
- Problems with WNR1000 Router
16-01-2011 4:28 PM
The BT engineer isn't coming for another couple of weeks yet so maybe I should try and get my hands on another router in the meantime or could it be it just isn't compatible with my DG632 set up as modem?
On another possibly unrelated note about the time all this was happening I've since been unable to connect to a small handful of websites, if I go through a proxy or on another internet connection they load fine but on my own connection they just never load.
Re: Problems with WNR1000 Router
16-01-2011 4:44 PM
If thats all gravy then possibly a faulty router?
16-01-2011 11:04 PM
I think I'll take my chances and see if it works with the new BT modem when it's installed and if not I'll have to plug the modem directly to my computer for the time being.
16-01-2011 11:28 PM
17-01-2011 12:14 AM
Just a bit annoying that it did briefly all seem to be fine but then suddenly all went dead and now seems impossibe to get back up and running.
17-01-2011 12:21 AM
Quote Label Activity Description
1. Power
Solid Amber The router is performing the power-on self-test diagnostic.
Solid Green The power is on and the router is ready.
Blinking–Amber A software update is in progress.
Blinking–Green Firmware is corrupted. See “Checking Basic Router Functions” on page 30 for instructions on restoring your router firmware.
Off Power is not being supplied to the router
17-01-2011 12:34 AM
So does this suggest there's something at fault with the router rather then a connectivity issue with my existing modem/router?
17-01-2011 12:46 AM
Quote Power Light Stays Amber. When the router is turned on, the Power light turns amber for
about 20 seconds and then turns green. If the light does not turn green, the router has a
problem.
If the Power light is still amber 1 minute after turning on power to the router:
a. Turn the power off and back on to see if the router recovers.
b. Clear the router’s configuration to factory defaults. This will set the router’s IP address to
192.168.1.1. This procedure is explained in “Restoring the Default Password and
Configuration Settings” on page 39.
If the error persists, you might have a hardware problem and should contact technical support.
17-01-2011 1:32 AM
Thanks for your help.
17-01-2011 8:58 AM
If this all fails, we will organise a replacement for you
17-01-2011 8:44 PM
How do I go about sorting a replacement? Should I add the details to the existing fibre trials ticket or should I start a new one?
18-01-2011 10:50 PM
I will try and find it tomorrow if I have time (as I normally deal with the Business ones).
- Full Fibre
