Ports not staying open
Ako
So my Hub two router opens ports automaticly, but after sometime (i say sometime because it ranges from a few days to weeks) the port closes and only way to get it open again is to reboot the router Sad
Any ideas?
6 REPLIES 6
Fixes: 1,495
Re: Ports not staying open
A bit more information would be useful, e.g. what ports and application and how do you know they're closed?
Ako
utorrent port 33012 & ace player port 8621.
I check them with canyouseeme.
bill888
Champion
Fixes: 40
fwiw, if you find uPnP is unreliable, consider setting up manual port forward rule on the hub.
fyi, I believe BT branded Home and Smart hubs perform an 'auto-reboot' every 14 days to help improve stability of the hub.   Plusnet hubs don't auto-reboot.
Ako
Hi bill888 that sounds like upnp is my problem.
i found the upnp setting, do i just turn that off?
ps. i'm a bit of a noob at this, so please be patient with me Smiley
bill888
Champion
Fixes: 40
yes you can turn off upnp on the hub 2.
Also check whether the apps have a upnp setting too.
you will still need to set up port forward rules on the hub 2.
I don't think Plusnet has a specific help page on the subject. This BT page for 'BT smart hub and Ultra smart hub' may help:
https://www.bt.com/help/broadband/learn-about-broadband/how-do-i-set-up-port-forwarding-on-my-bt-hub...
Ako
Thanks bill888
ports manually setup with upnp off, just got to wait a few weeks now and see if ports stay open Smiley
