Porting landline number to VoIP and keeping FTTP
janswer
Hi, I'm currently on the FTTP trial, which has been brilliant. I have a BT landline which remains largely unused, and I'm thinking about porting the number to a VoIP provider. Can I just double check that this won't trigger the cancellation of my broadband? I believe that's the case from reading other posts here, but I wanted to make sure.
2 REPLIES 2
Aspiring Hero
Fixes: 33
Re: Porting landline number to VoIP and keeping FTTP
@janswer
You need to get an FTTP trained member of staff like @Gandalf to response and give a definitive answer.
Although it's a BT landline who provides your phone service? If it's BT then you'll have no problems (I believe!!!!). If it's PlusNet then you need to work with them to port the number. Cancellation of a phone service can lead to account closure due to the way their systems work.
There's a £2.50 surcharge for Internet only on PlusNet but you should already be paying this if using BT for your phone service.
I (like 3 of my neighbours) gave up my phone line almost as soon as I was on the FTTP Trial. Never missed it as a mobile covers any need for a phone.
Fixes: 1,552
Thanks for getting in touch @janswer
As we're not providing your phone service, moving your landline number to VoIP will have no effect on your FTTP with us.
Let us know if you've got any further queries
