Poor speed + disconnects again.
sw4mpl0rd
Hello again.
I'm getting terrible speeds again, not close to what I'm paying for.
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 40 - 57Mbps
  • Estimated Upload Range: 7 - 12Mbps
  • Minimum Guaranteed Speed: 35.3Mbps
  • Current Line Speed (Download): 12.3Mbps
It's usually around 50mbps. This happens every month or so. I get disconnects, speed lowers rinse / repeat.
I've attached the BT wholesale checker.
Really, really fed up here.
Any help would be very much appreciated
tested wired, into the test socket
9 REPLIES 9
Fixes: 334
Re: Poor speed + disconnects again.
Normally, my response to a BTw test result like this would be:Report a fault at: https://faults.plus.net , but if you want someone to look at it - not PN Help Team as they work to a script - try this, ignoring the test you have already completed:
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
sw4mpl0rd
I've attached the screengrabs as requested.
I've also opened a fault
Cheers!
Mustrum
Fixes: 81
Do you have a static ip?
The sync speeds seem ok, its the current line speed on the PN side that is low, suggesting a stuck or wrong profile in the PN system.
sw4mpl0rd
Yes, I do have a static IP
ta
adamwalker
Fixes: 223
Hi there, I've just been looking into this for you and tests are showing signs of a line fault (impairment in copper joint) so we'll need to arrange an engineer visit with you. I've added a ticket to your account with more information here: https://www.plus.net/wizard/?p=view_question&id=222611406
Please let me know when you've responded and I'll get that booked in for you.
 Adam Walker
sw4mpl0rd
I've responded! Cheers
adamwalker
Fixes: 223
No problem, I've just made the booking for you and updated the ticket, I really hope the engineer gets this resolved for you and please let me know if there's anything else I can help you with in the meantime.
 Adam Walker
sw4mpl0rd
It's been happening on and off for 3 years so I'm not going to hold my breath!
Thanks for your help though.
I'll update if it gets resolved.
Cheers
adam945
Fixes: 113
I ca understand that @sw4mpl0rd, let's see how things go though and we'll be happy to follow up. Smiley
 Adam
 Plusnet Help Team - Leeds
