Plusnet Wasters
Stringwalker
Plusnet Wasters
Thanks Plusnet for taking away my step kids internet, you Wasters.
4 REPLIES 4
Edinburgh_wg
Re: Plusnet Wasters
Typical passive aggressive, isn't it? Plus using emotional blackmail (kids), not to mention inappropriate language (wasters).
If you provide a description of the problem, Plusnet might try and help you. Other than that, they're not mind readers.
Fixes: 480
Re: Plusnet Wasters
The only time that Plusnet ‘take away’ your service is if you fail to pay your bill.
Of course there might be a fault in the Openreach equipment over which Plusnet provide the service.
Alex
Fixes: 13
Re: Plusnet Wasters
Can you explain more about your problem? It may not necessarily be PlusNet.
jim13
Re: Plusnet Wasters
Did he/she pay his/her bill? It usually helps.
