Plusnet Hub One Constant Green Light
Parallax
I tried connecting my Plusnet Hub One for the first time this week. The green light flashed for a while before turning constant green, but there is no internet connection and I can't access the admin panel. I've tried switching it on and off, disconnecting and reconnecting it from the power and holding the reset button down for more than a minute, but the light remains green.
3 REPLIES 3
MatthewWheeler
Fixes: 503
Re: Plusnet Hub One Constant Green Light
Sorry to hear this.
Based on the information you've given it's likely that the router has developed a fault.
I've requested a new router is sent out to you with a returns bag for the faulty one.
If you can post back here when you've received it we'll refund you for the downtime
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Parallax
Many thanks - the new router has arrived and seems to be working. I'll get the old one returned to you this week. Thanks very much for sorting this.
Fixes: 1,662
No problem, and that's good to hear your new router is working fine now.
Let us know if you need any further assistance.
