Plusnet FTTP router setup - static routes
clanla
Hi
My nice new FTTP broadband is up and running I am glad to say and I am just trying to setup the router. I can't find how to setup static routes, can someone help.
Also it would be useful to know what router it is based on. The FTTP FAQ [1] says it is a Technicolor TG582n but I don't think that is correct.
I searched the forum but could not find anything relevant to the FTTP router.
Colin
[1] https://community.plus.net/t5/custom/page/page-id/_FttpFaq
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: Plusnet FTTP router setup - static routes
Apologies, please disregard my response (now edited).
I can see you've managed to connect up, I'm not sure how/if static route can be set on the Plusnet Hub One router I'm afraid, what are you trying to achieve?
https://community.plus.net/t5/Fibre-To-The-Premises-trial/Waiting-for-OpenReach-to-complete-outside-...
clanla
Hi Chris
Thanks for helping. For example I run a VPN server so I can connect into my network when away. To configure that I need to be able to route 10.8.0.0/24 to my vpn server (192.168.1.83).
Colin
Aspiring Hero
Fixes: 39
Can't help with static IP or VPN but the following PlusNet support pages may help with your router.
https://www.plus.net/help/broadband/router-setup-guides/
https://www.plus.net/help/broadband/broadband-connection-settings/
clanla
Hi Brian
Thanks for the suggestions, but I am trying to setup a static route, not a static IP.  I have looked at those links again and I don't think there are any references to static routes there.
Colin
