Ping time >200ms
markavey
Ping time >200ms
I'm getting very high ping times - generally over 200ms, often over 300ms.
I've tried switching DNS providers, but it stays pretty much the same.
Any ideas? Is a line check required?
Thanks,
Mark
20 REPLIES 20
Re: Ping time >200ms
Ping times mostly depend on the distance (or length of route) to the site you are pinging,
OR
by the delay caused by your router IF your UPLOAD path is being heavily used (due to "bufferbloat").
Try pinging a nearby site to see whether you still get >200ms - I use  ntp.plus.net
To test for "bufferbloat" try using  http://www.dslreports.com/speedtest
Changing DNS providers won't make any difference to ping times.
Probably not,  only if your line speed had dramatically slowed as well - which you would have mentioned
tallbox
This is terrible.
I have 215ms ping as well, and it's not only me. Few people around the town I know have the same issue with Plusnet.
Come to one Plusnet, fix this; we can't work from home with this.
It's even painfully slow to open the forum here.
I've just renewed my contract, but I'll have to revoke the entire thing if this continues.
<a href="http://www.dslreports.com/speedtest/69444853">
<img src="http://www.dslreports.com/speedtest/69444853.png"></a>
Oh no !  I'm getting  5.6ms to  ntp.plus.net   and  A+  on the "bufferbloat" test  🤣
tallbox
Just did what  you suggested:
Bufferfloat averages between 50 to 900.
Before July everything worked fine, so strange.
markavey
Thanks for the tip, but:
"The server at ntp.plus.net is taking too long to respond" - it won't load the page
markavey
Here's my results from bufferbloat test
http://www.dslreports.com/speedtest/69444893
?  you meant to be pinging that address, not trying to view it on a web browser.
Open a terminal window and type -
ping  ntp.plus.net
 or whatever the equivalent command is for your operating system
How were you testing ping before ?
I get this -
$ ping ntp.plus.net
PING ntp.plus.net (212.159.13.49) 56(84) bytes of data.
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=1 ttl=61 time=6.14 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=2 ttl=61 time=5.90 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=3 ttl=61 time=6.31 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=4 ttl=61 time=6.21 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=5 ttl=61 time=6.38 ms
markavey
Ah, sorry, misunderstood.
Weird, just did the ping from the command line and now down to 21ms. Tried again on Speedtest (which is what I originally used) and down to 22 there. So perhaps just a temporary hiccup?
That doesn't look right.
Are you on ADSL or FTTC ?
If you are on ADSL then the download speed is being reported incorrectly.
If you are on FTTC you should be getting way more upload speed - unless someone else was uploading something at the same time as you did the test.
markavey
I'm on Unlimied Fibre Extra, so FTTC?
No uploads were taking place so far as I know. Upload speed has always been bad, but I'm not overly concerned with that.
markavey
Re-test results with Fibre selected: http://www.dslreports.com/speedtest/69445006
RobPN
Fixes: 14
@markavey
Probably of no relevance, but here's mine for comparison;
http://www.dslreports.com/speedtest/69445176
Unfortunately it is technically quite challenging to overcome "bufferbloat" and the associated high ping problems on a broadband connection with an upload throughput of less than 1mbps, and ideally you need more than 2mbps.
What does the "BT Broadband Availability Checker"  show for your "VDSL Range A" and "VDSL Range B" ?
Go to this website -
https://www.broadbandchecker.btwholesale.com
then -
    enter your telephone number
    enter the Captcha code
    click on [Submit]
So you know what to look for, mine looks like this -
markavey
adsl.PNGadsl.PNGHere's my results
