Ping issue
Eatpower
Ping issue
I am experiencing intermittent severe latency spikes and rubber-banding on my Plusnet Full Fibre connection. My normal latency is around 21–23 ms, but it intermittently rises significantly and causes real-time online games to freeze and rubber band.
I have carried out extensive troubleshooting at my own expense. I tested the installed Ethernet wall connection with an RJ45 network tester and all eight conductors pass correctly. I also completely bypassed the wall wiring with a separate 10 meter Cat6 cable and the same issue occurred.
The issue has also been experienced on more than one wired device in the household, so it is not isolated to one PC or network adapter.
I have now replaced my ASUS AX6000 router with a brand-new ASUS ROG Strix GS-BE7200 and used the new Ethernet cable supplied with it between the Openreach ONT and router. The new router was configured from scratch. Despite this, the high latency and rubber-banding have returned.
I have been using PingPlotter and recorded large latency spikes to external destinations such as 1.1.1.1, so the problem is not limited to one game server. Normal download speeds can still be achieved, so this appears to be an intermittent latency/jitter issue rather than simply a throughput problem.
Given the amount of internal equipment and cabling I have now eliminated, I would like Plusnet to investigate the FTTP connection, ONT and network side for intermittent errors, packet loss, latency/jitter or optical issues, and escalate to Openreach if appropriate.
Tags (3)
11 REPLIES 11
markhawkin
Champion
Fixes: 22
Re: Ping issue
Set up a Thinkbroadband Broadband Quality monitor and see what that shows.
https://www.thinkbroadband.com/broadband-quality-monitoring
I assume you are using a cabled connection as WiFi will be prone to latency spikes however fancy the router is.
bobpullen
Fixes: 330
Re: Ping issue
@Eatpower wrote:
I tested the installed Ethernet wall connection with an RJ45 network tester and all eight conductors pass correctly. I also completely bypassed the wall wiring with a separate 10 meter Cat6 cable and the same issue occurred...
What's the situation with the wall wiring? Are we talking 'proper' structured cabling or are you using something like Powerline adapters (in which case all bets are off)?
Are you able to share your PingPlotter results?
@markhawkin's suggestion is a good one. You will need to configure your router to respond to pings/ICMP on its WAN interface (which I'm fairly certain the Asus kit permits).
Eatpower
Re: Ping issue
Hi, it’s a proper hardwired Ethernet run between faceplates, not Powerline. I bought a Philex Network Cable Tester and tested both Ethernet patch cables as well as the wall run/faceplates. Both patch cables and the hardwired run passed the full 1–8 sequence with no breaks or missing conductors.
I’ve also bypassed the wall run entirely with a separate long Cat6 cable and still reproduced the latency/rubber-banding issue.
I also tried to get an electrician who specialises in networking to inspect it, but the people I contacted were fully booked for around two weeks.
Eatpower
Re: Ping issue
markhawkin
Champion
Fixes: 22
Re: Ping issue
Well I'm a bit puzzled.
Assuming I'm understanding the picture correctly the first target
(something)cal (perhaps local)
has a minimum ping of 0.2 - I guess it's something on your LAN yet is currently 694.9 ms from another device on the LAN
The next device is also probably close as the minimum ping is 1 ms. That's also got a high current ping.
On my home network (I run Smokeping) the router is less than 0.5ms average and Google's DNS about 3ms average.
Is some device flooding your network with traffic?
This doesn't look like a WAN issue to me at first glance.
Eatpower
Re: Ping issue
Most devices in the house are phones/tablets or smart devices and were either idle or doing very little at the time. There wasn’t any obvious large download/upload taking place. I’ve also reproduced the latency while bypassing the structured wall cabling with a separate Ethernet run, and I’ve since changed the router as well. In the PingPlotter capture, the latency wasn’t confined to the first hop it continued through subsequent hops and to 1.1.1.1 itself. So I’m not sure a LAN device flooding the connection fully explains what I’m seeing.
markhawkin
Champion
Fixes: 22
Re: Ping issue
My theory was rather the converse.
If the problem were in the wider network (WAN) then I wouldn't expect the ping to the router to be slow (as that doesn't use the Plusnet provided connection to the Internet).
That's what puzzled me.
ExForce9
Seasoned Pro
Fixes: 10
Re: Ping issue
@Eatpower
What is the exact model of AX6000 do you have ?,
as apparently "ASUS AX6000" can refer to RT-AX88U / RT-AX88U Pro, or GT-AX6000, and others.
What firmware do you have installed on it ?
Eatpower
Re: Ping issue
It was the ASUS TUF Gaming AX6000, model TUF-AX6000. It was running the latest firmware, version 3.0.0.4.388_34013.
I’ve since replaced it with a brand-new ASUS ROG Strix GS-BE7200, so the TUF-AX6000 is no longer part of the setup.
bobpullen
Fixes: 330
Re: Ping issue
@Eatpower - the average pings on your PingPlotter screengrab don't look all that bad. The current values are through the roof though.
The two hops with packet loss you can ignore, they are just devices that don't always respond to ICMP traffic.
As @markhawkin has alluded to, if that first hop is to your router (is it?), then it's showing over half a second response time between the device running PingPlotter and the router which would be indicative of something specific to your LAN.
Eatpower
Re: Ping issue
Yes, that first hop was my router. I understand why the high response time there suggests something local, but I’m struggling to reconcile that with the other symptoms I’ve seen. On at least one occasion the PC actually lost the Ethernet link completely because the router showed the LAN port as disconnected and the switch uplink light went out. I’ve also had Overwatch disconnects/rubber-banding.
I’ve since replaced the router, replaced the suspect Ethernet lead, and I’ve also reproduced severe latency while bypassing the structured wall cabling with a separate direct Ethernet run. So I’m wondering whether there may have been more than one issue rather than a single LAN fault explaining everything.
