Pending connection to Full Fibre
SteelCity1
Connection is due to change from FTTC to Full Fibre. Some properties on this cul de sac are connected to the pole and my neighbour across the road recently had hers connected to it for FF.
My broadband/telephone has always been underground. Question is, will I have to have an overhead wire too? The pole is quite close to the property.
15 REPLIES 15
Fixes: 382
Re: Pending connection to Full Fibre
@SteelCity1 Your Full Fibre connection will be underground, via the same ducting. To confirm, can you please post the full output from : https://www.broadbandchecker.btwholesale.com/#/ADSL  or https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome  (if your connection is currently SOGEA). In both cases, redact any personal detail.
Fixes: 579
@SteelCity1 what does the availability checker https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome say for your address , particularly the narrative below the availability results
edit:John just beat me to it...
SteelCity1
Thank you for the replies. Here is the output from the Broadband Availability Checker:
Fixes: 579
@SteelCity1 looks like the fibre IS going to be an overhead feed from the pole.
I guess if there was already poles , then it was easier for Openreach to use those for the FTTP rather than dig ducts.
Fixes: 382
@eleted - @MisterW  beat me to it, and I didn't spot the bottom line.
SteelCity1
Fixes: 579
The checker shows 'no anticipated issues' and a '1-stage' install i.e everything done in one visit.
So I would assume its a straighforward fibre from the nearest pole, secured at the eaves, then run down to ground floor level and the CSP located there. Then internal fibre through the wall to the ONT located internally.
SteelCity1
Oh, that is a shame. I really did not want that. I know it sounds petty, but that’s how I feel so can’t be helped. I don’t know whether to ask if I could cancel now. Is it possible? Installation is over one week away.
Thank you for your replies. Much appreciated.
Fixes: 382
Oh, that is a shame. I really did not want that. Why?
SteelCity1
I just prefer not to have an overhead connection. Underground seems better.
Fixes: 382
What difference does it make - honestly?
@SteelCity1's
Current underground feed may be "Direct in Ground", and therefore no duct to route the new fibre through?
Fixes: 117
@SteelCity1
While it appears it's going to be an o/h connection you speak to the installer on the day to agree the works. If an u/g connection is possible they may well do it.
However the fibe cable feeds back to a Connectorized Block Terminal (CBT). You'll see one at the top of the pole. There may not be one in the u/g chamber serving your house.
On a related point, there is some leeway as to where the internal Optical Network Terminator (ONT) is situated. If going overhead you may have the choice of 2 external walls for the external cable to be attached which would help with the siting ot the ONT. Remember it needs a power source.
Fixes: 382
@Anonymous wrote:
@SteelCity1's
My thoughts too - Full Fibre is, AFAIK, not done as DIG.
