OpenReach ONT RED LIGHT
jodyemery
Hello,
Thursday evening ONT mounted by OpenReach engineer fall off the wall, as he did stick it to the wall with double sided tape.
Since then this ONT shows RED Light on LOS and since then i do not have internet.
Restarting did not help, unplugging and then plugging wires did not help either.
I Texted HELP and FAULT many times but nothing happened, maybe due to easter long weekend... But i need connection
anything?
EDIT: + PON light does not show anything
Regards,
5 REPLIES 5
Fixes: 585
Re: OpenReach ONT RED LIGHT
Quite possible that it's damaged the ONT  or the fibre connection to the CSP.
Call Customer services and report the fault
jodyemery
I registered here only because no one answering there, and their system of HELP texting or FAULT texting does not do anything xD
I will try tomorrow again, as bank holiday goes away
csmith94
Fixes: 31
Hi @jodyemery
I'm really sorry to hear you've got no service, I've ran a line test and will be able to get an engineer booked in for you to investigate further.
Openreach operate 2 timeslots for visits. These are AM ( 0800-1300) and PM (1300-1800), Monday to Friday
Please provide 3 timeslots you could attend and we will book the appointment for you and contact you to confirm when the engineer will be visiting.
Please note if an engineer visits your premises and is unable to gain access or if the fault is found to be caused by your equipment, your set up or your phone socket, the engineers may refer you back to us to discuss the next steps.
 Curtis Smith
jodyemery
Hello,
AM slot 8-13 is perfect as my boyfriend is at home till 13:30.
Any day except fridays will do.
Regards,
csmith94
Fixes: 31
Thanks for letting us know, I've got an appointment booked in for the 12/04/23 between 8AM & 1PM. The Engineer will attempt to resolve the fault externally first before coming round, they will keep in touch on the day of the appointment.
Once the Engineer has been, our Faults Team will follow up to make sure everything is ok or if anything else needs to be done.
 Curtis Smith
