Only getting 18 to 30 mps on a 145 mps contract
Wazza1965
Hi 4 days ago I switched from copper line to optical full fibre , my mps is lower than I had before typically 18 to 30 mps, any advice would be appreciated.
16 REPLIES 16
Fixes: 524
Re: Only getting 18 to 30 mps on a 145 mps contract
Is that a wired ( ethernet cable direct to router ) or wirelsss test ?
krusty
Are you conducting this speed via a wireless or wired connection.
Have you changed router?
if its the same router, have you tried a router reboot ?
Wazza1965
It's the same router hub 2 and it's a wireless test, I've rebooted router.
krusty
Can you try a wired test please. Wireless has too many variables to get a consistent result
Wazza1965
I've no means of doing a hard wired test, the picture when streaming is low quality sometimes worse than others.
Fixes: 524
That's not ideal, but try doing a test making sure that the device is connected to the 5ghz wireless and not the 2.4ghz
Wazza1965
How do I do that please
Fixes: 524
Check using the Devices list on the Hub GUI. It should show which band each device is connected to.
On the device, check that 'prefer 5ghz' is set (if its available) in the wireless settings
Wazza1965
Hi I checked on router settings and my device is on 5
Fixes: 334
Out of interest, what is your 'device'?
Fixes: 524
Ok, just re-reading the thread
Is it physically the same router OR just the same model ?
Has the router changed position in the property ? ( I'm thinking maybe closer to a neighbouring wifi and thus suffering interference )
Wazza1965
It's the router lve had it for about 3 years, it's in exact same place.
Fixes: 457
I assume that the DSL lead is disconnected?
Try a factory reset on the hub by pushing a paperclip or similar in the reset hole. Hold the seitch closed until you get a Green light.
Wazza1965
I've just tried that and mps went up to 45mps
