Now showing FTTP on Demand
Mav
Fixes: 510
The dslchecker is now showing FTTP on Demand as available so does that mean it is unlikely that FTTP will be available in my area?
FTTC is available (Minster cabinet 1) but only 2.7-3.7 Mbps against the 4.5-5.3 Mbps that I am getting on ADSL2.
Forum Moderator and Customer
13 REPLIES 13
HarryB
Fixes: 256
Re: Now showing FTTP on Demand
While I really don't know what this means for the likelihood of WBC FTTP becoming available, I think most places with FTTC availability end up showing FTTP on Demand.
Fingers crossed for the best, but I would get your hopes up too soon.
 Harry Beesley
Mav
Fixes: 510
thanks for the quick reply @HarryB
I am guessing you meant:
but I wouldn't get your hopes up too soon
CryCry
HarryB
Fixes: 256
If it makes you feel any better, I'm in the same boat.
Although my fibre speeds aren't quite as bad as yours, they're better than the 2-4Mbps I used to get on ADSL.
 Harry Beesley
Teece
@Mav - I find this very surprising - given that FTTC will be using less of the same copper than the ADSL2 service is running on.  Can you post the screenshot from the checker?
Browni
Aspiring Hero
Fixes: 60
It's not that unusual as due to FTTC using higher frequencies it is attenuated more therefore not as effective over the same distance.
Mav
Fixes: 510
It doesn't help that the copper wiring seems very poor (unless it's aluminium) as I only ever connect at ASDL2 and not 2+ speeds hence getting nowhere near the estimates.
Oddly the ADSL2+ estimates used to be something like 3 to 5Mbps before FTTC appeared in the checker.
HarryB
Fixes: 256
I believe that happened on my line too when FTTC appeared.
I'm just testing your line now regarding the slow speeds.
 Harry Beesley
pjmarsh
Fixes: 19
@Teece, it isn't too surprising.  VDSL (as used in FTTC) looses it speed over a much shorter distance than ADSL2 does:
Edit: Oops, lots of activity whilst I was digging out the image!
HarryB
Fixes: 256
@Mav Testing isn't pointing out anything obvious Undecided
xDSL Status Check
Circuit ID: Removed Service ID: Removed
Telephone NO.: NA Test Executed On: 26-04-2017 12:29:47
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status:   NTE Power Status: PowerOn Bypass Status:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 27.3 47.0
SNR Margin: 6.0 7.6
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 7942103 7939400
Speed: 816 4800
Maximum Stable Rate (KBPS): 5120 Fault Threshold Rate (KBPS): 4096
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 1215
Indicative Line Quality: A Mean Time Between Errors Downstream (Seconds): 3738
May be worth having a run through the troubleshooting steps to check internal wiring etc.
But by all means, please do raise a fault over at http://faults.plus.net if troubleshooting doesn't help improve the speeds.
 Harry Beesley
Teece
We have a long copper run, and the ADSL2 speeds are significantly lower than that graph suggests, whereas the FTTC speeds are comparable.  Odd!
pjmarsh
Fixes: 19
It could be the length of the cable from the cabinet to the exchange is longer than you think (it doesn't always take the most direct route), or the quality of that cable isn't too good, which is why you're seeing the slower speeds on ADSL2.
Browni
Aspiring Hero
Fixes: 60
Remember with ADSLx the signal has to travel from all the way from the exchange, with FTTC it effectively is only traveling from the cabinet.
Mav
Fixes: 510
@HarryB
Thanks for the printouts and checking things your end.
The Router is plugged into the test socket in the master socket with a filter and there are no other devices/extrensions connected.
I did raise a fault a few weeks ago in the hope something may show up but that didn't show anything untoward.
Looks like I may just be stuck with a reasonably long and poor lineSad
