No usable internet
Ndbrails
No usable internet
My internet connection went down overnight. The router indicates it’s connected to the internet, and the ONT has green lights. I’ve restarted everything, but the problem persists. I reported it to tech support about an hour ago and am still waiting for a call back. Anyone else having trouble?
15 REPLIES 15
keeka
Re: No usable internet
I did have something very similar but it connectivity is ok now with moderately worst latency.
See my post shortly before yours.
Fixes: 575
 Yes lots !! https://community.plus.net/t5/Broadband/dns-block/td-p/1970427/jump-to/first-unread-message
briank
Same problem - although it seems to have now started working as of about a minute ago.
briank
Correction - some websites are still not available.
I am unable to access NHS Login.
briank
Now it works.
Ndbrails
Been stable for a while now
SammyM
Fixes: 101
Thanks for your patience and I'm sorry you are having an issue with your connection.
The issue should now be resolved, please can you reboot the router and try to connect.
 Sammy M - Sheffield Team
Ndbrails
Thanks it’s much better however the speed is low at present.
keeka
I haven't come across an explanation of this morning's 'outage'. What I did find interesting was comparing
https://downdetector.co.uk/status/bt-british-telecom/
https://downdetector.co.uk/status/plusnet/
Almost mutually inverse of one another! Is that big brother BT temporarily requisitioning PN's capacity? 😋
Ndbrails
How is your download speed at the moment?
keeka
DL is about what is supposed to be and latency is slighly above normal.
Ndbrails
Mine is very low. Thanks though
willcutforth
Fixes: 113
@Ndbrails what speed are you getting on your side and is it testing it via wired or wireless?
 Will Cutforth
Ndbrails
Hi there, I’m getting 90mbps on both wired and wireless, before yesterday I was getting 280
