No response to Trial request
- Full Fibre
- No response to Trial request
21-07-2017 2:13 PM
Hi
Completed a ticket for FTTP trial over a week ago but have as yet had no response. Have had confirmation of availability from BT and neighbours pole has the required fitting!! Can you help? Thanks Steve
Re: No response to Trial request
21-07-2017 2:43 PM
Few staff are trained up on this so replies depend on who's available and when. The Trials page does say it can take 7 - 14 days to respond.
Does the DSL checker say something like "WBC FTTP" available.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it does, and you're an existing PlusNet customer, then it's usually just the time it takes to set up.
21-07-2017 2:49 PM
Welcome to the community forums @mockneysteve
I've checked your account and it looks like the FTTP Trial ticket was picked up around 10 minutes after you made this post.
21-07-2017 3:02 PM
Thanks for your replies, .75 mbps to 80mbps !! It's gonna be good to be going back to civilisation !!
08-08-2017 9:34 AM
We have a provisional engineer appointment for today (8am - 1pm) for the internal work, all external work was completed over a week ago. Is todays visit still going ahead as it has not been confirmed?
08-08-2017 11:28 AM
08-08-2017 11:31 AM
As soon as you replied he tuned up
I'm now sat like a kid at Christmas waiting to unwrap my present
08-08-2017 12:04 PM
Great timing, hopefully the install goes well.
08-08-2017 1:12 PM
All neatly installed by the Openreach guy. Plugged in the Plusnet Hub One and worked straight away ! No more sharing the WiFi
Speed is only! around the 20mbps mark, he said this would fluctuate over the next 10 days though, is this correct? We were told to expect around the 70/80 mark. 20 compared to 1.5 is enough to keep me happy for the time being though
08-08-2017 1:18 PM
That's likely just because your account was still on an ADSL package.
Could you try disconnecting/reconnecting the router as I've just upgraded the account to a fibre package for you.
08-08-2017 2:19 PM
Have rebooted router and now having very mixed results, a few under 10mbps, 1 at 79mbps and a few averaging 20-25mbps ?!? I'll keep checking, do you have a recommended site for speed tests ? I've used Googles and Broadband Speed Checker and they both vary their results !
08-08-2017 5:39 PM
The result you've received at 79mbps looks promising.
We'd recommend the wholesale speedtest site here: www.speedtest.btwholesale.com
08-08-2017 7:43 PM
Also, are you connected to your router wirelessly or via Ethernet cable?
08-08-2017 9:29 PM
- Full Fibre
