No PON light on Openreach modem
- Full Fibre
- No PON light on Openreach modem
22-11-2019 1:07 AM
We have fttp onto the ONT which is linked to a google Wi-fi. The connection was down on Thursday night and as I wasn’t around there was some miscommunication in my family and the google Wi-fi box got factory reset instead of being turned on and off Going through resetting this up and can ’t get it to connect using the Ppoe setting using my username@plusd.net and password. I have tried connecting my laptop directly to the ont modem and starting a new dial up over ppoe but getting the same connection failed error. The ont box lights on but the PON light is off (although it did come on late last night). When I got in this evening (didn’t get it working last night) the LOS light was red until I restarted it and now neither PON or LOS are lit. Any suggestions? We do have Vodafone digging up the estate I live on to our in fttp for everyone (even though I already have fttp!). Could this fault be a result of the works, can my line be checked? Any other suggestions?
Re: No PON light on Openreach modem
22-11-2019 12:16 PM
22-11-2019 12:59 PM - edited 22-11-2019 1:03 PM
@JL86 wrote:
... can ’t get it to connect using the Ppoe setting using my username@plusd.net and password.
Presumably the 'd' in your username as quoted above is a typo and you're not including it in the actual username you're typing?
See my correction below.
Edit: I said that because my login details are accountname@plus.net as I have an older account, yours would most likely be accountname@plusdsl.net
22-11-2019 1:07 PM - edited 22-11-2019 1:07 PM
Hi @JL86 I'm sorry to see you're unable to connect to your FTTP service and for the delayed response. I can see you've got in touch with our support team and we've booked an engineer for tomorrow morning to investigate this.
I can't run a test down your FTTP service as there's an open fault with Openreach (We just get 'Test Rejected' error when we try) however I've pulled up the results from the adviser's test around an hour ago.
Unfortunately it's not uncommon for remote tests on an FTTP connection to show very little to no useful information:
Having said that, I've checked the connection logs of the BT servers, and the last attempt to connect into the BT network was Wednesday at 18:39 PM.
It sounds like you've done what you can to get back online, so I'd say an engineer is the next step.
Let us know how the appointment goes tomorrow.
22-11-2019 1:07 PM
28-11-2019 5:29 PM
28-11-2019 6:03 PM
Thanks for getting back to us @JL86 I'm sorry to see you're continuing to experience connection problems with your FTTP service. Could you reply to your fault ticket Here with further availability when you'd be free for an engineer to visit?
This would likely be next week as there doesn't look to be any Saturday timeslots this time around unfortunately. Once you've added a reply to the ticket, I'll get the appointment booked in and this escalated with our suppliers.
Apologies for the inconvenience this causes.
- Full Fibre
