No Internet
Manda30
No Internet
Since last night around 2 am our Internet connection has been dropping like every 5 minutes, it'll go blue for abit then go to flashing orange with a orange b symbol, Internet is unusable today. Even after restarts and hub manager it'll do the same thing
Tags (1)
11 REPLIES 11
Fixes: 387
Re: No Internet
@Manda30 Welcome to the forums. Sounds like you have a problem there, but before I  offer any advice, can you confirm you are on ADSL - the two technologies do have different characteristics and resolutions in this scenario?
Manda30
Re: No Internet
Is adsl the same as dsl?, sorry I'm not the most knowledgeable with Internet
Fixes: 387
Re: No Internet
Sorry, @Manda30  - I sometimes forget not everyone is IT literate. To answer your question - no. A slightly easier question - what speeds do you get when things are running correctly?
Manda30
Re: No Internet
I think it's about 26mbps and our package is unlimited fibre extra if that helps
Fixes: 387
Re: No Internet
Right - so you are on Fibre - that helps. I will ask the mods to move this to the correct board.
You say you are not internet savvy - how good are you at following instructions, just so I know how to proceed?
Manda30
Re: No Internet
Thank you I appreciate that and your patience, I can follow instructions
Fixes: 387
Re: No Internet
OK - that's good. While we wait for the topic to be moved to the correct board, this is my 'boiler-plate' standard response:
For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
Anything you don't understand - feel free to ask - I have no problem helping those who help themselves.
Manda30
Re: No Internet
The landline won't ring the number just dead silence while putting it in and after putting it in
Fixes: 387
Re: No Internet
In that case, you have a PHONE fault, which needs sorting first, and may even rectify the broadband issue. I would suggest ringing Plusnet ASAP and reporting that, and we can look at the BB side once that is sorted.
Fixes: 1,495
Re: No Internet
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
adam945
Fixes: 113
Re: No Internet
Really sorry for the inconvenience caused here @Manda30, but thank you for taking @jab1 's and giving us a call. Looks like you have an engineer visit arranged for this morning. Feel free to reach out if you have any further issues afterwards. Smiley
 Adam
 Plusnet Help Team - Leeds
