No Internet - red light for LOS indicator on ONT
hmarshy
Re: No Internet - red light for LOS indicator on ONT
Just did a quick search to try to figure out where the splitter may be located on an FTTP network and found this image:
If the splitter divides the signal for different customers then you would have thought it would have affected other FTTP customers and not just me.
I don't know 🙄 I suppose I am just guessing how it works. 🙃
Regards
Howard
Fixes: 1,639
I don't know much about the engineering side of FTTP, but that's my understanding too. While Openreach do regular maintenance on their infrastructure, it's possible that some equipment can fail before anticipated.
Fixes: 87
@hmarshy
I knew each fibre serviced a number of customers so it looks like 32 is the magic number. Further back up the line there's probably aggregation nodes to consolidate fibre strands.
As to your problem it could well be yours was the first connection to fail so OR will have been able to replace it before anyone else had problems.
bobpullen
Fixes: 327
@hmarshy wrote:
Just did a quick search to try to figure out where the splitter may be located on an FTTP network...
Normally on a distribution pole, or in a pavement chamber i.e. fairly close to your premises.
Fixes: 87
@bobpullen
I'm guessing the sequence is
Internet Head End - Aggregation Node - Splitter - Distribution Point - Customer
Given the DP's can be daisy chained the splitter could be some distance from a house.
Got me thinking about my connection. I live in a "circle" of about 50 houses.. I know the DP (8 customer nodes) that serves my house is the last on a daisy chain. Thing is, counting backwards leaves about 6 houses at the start of the street once I get to 32. There are about 9 after me which I know are on a separate circuit.
So it would appear there is a splitter further round the street from me but two groups of houses appear to be served by splitters elsewhere.
Fixes: 87
Although an old web page the following might be of interest.
blog.thinkbroadband.com/2016/06/a-peek-at-the-future-world-of-openreach-fttp/
