New issue - continual fibre disconnects
PeteM
I've been experiencing fibre drop outs this evening and this morning a cycle of drop outs until I turned the router off for 5 minutes. I've got the router plugged into a new Openreach Master socket. May be unrelated, but this does seem to happen about once a year about this time. Last time I raised a fault here, and it sorted itself when someone had a look at my logs.
One phone in the house, believe the line to be fine.
Could someone have a look for me ?
Many thanks,
Pete
3 REPLIES 3
Fixes: 357
Re: New issue - continual fibre disconnects
@PeteM PN support is very thin on the ground at weekends. If you follow this 'guide', I or one of the other regular old-timers may be able spot the possible cause:
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
PeteM
Thanks John,
I've looked at my Archer's router logs this morning, and as far as I can see the line has been connceted since 2:45 this morning, so it might have fixed itself.
I've done the quiet line test, and it's quiet - I've attached the 2 other BT tests. I'll have a look at the test socket stuff shortly
Pete
Fixes: 357
Thanks for that, Pete. The BT speed test looks OK, but I'm a little concerned that you have only been connected since 0245 - this suggests further disconnections later yesterday.
Good that the phone test passed, one thing to cross off the list. You can ignore the test socket stuff, that was only really if the QLT suggested a problem.
Keep  your eyes on the connection, and report a broadband fault if you get more drops.
