New hub or not ?
brid1965
New hub or not ?
at the moment i have FTTC with the home hub 2 ....(plusnet)
i've just upgraded my package to FTTP 300 ....
i presume i'll carry on using the existing hub 2 ?
also will there be any setting that need changing ?
thx in advance.
2 REPLIES 2
Fixes: 382
Re: New hub or not ?
@brid1965 You carry on using the same Hub, and no, there are no settings you need to change.
Fixes: 480
@brid1965
You use a Hub 2 but the DSL cable has to be removed. instead you need an Ethernet cable to connect the WAN socket on the hub to the new FTTP ONT.
 FTTP versions of the hub 2 has this cable in the box instead of the DSL one.
