New Full fiber connection
andyfzr
I've just had full fibre fitted but I'm only getting 30mb. Do I need to get a faster router cos I'm using the same one I already had. I thought plus net would of sent one
34 REPLIES 34
Fixes: 334
Re: New Full fiber connection
Which router are you using, and have you had text and/or email from PN confirming your FF connection is live?
andyfzr
It's a Plusnet hub I think. Same one I had with part fiber. No I've not had notification from them. The engineer was very rude and moaning all the time. He just said your back on now and my router will be fine. I was getting 15mb on half fiber and I signed up for full300 but only getting about 40 to 50mb. I get it that it takes a few days but I thought it would be slot faster, even now. Thanks
Fixes: 124
@andyfzr
Does the hub have a
single blue light across the middle - Hub One
or
a circle with blue lights at the top and bottom - Hub Two
You need to be testing using a ethernet wired connection for a true reflection of speed
Fixes: 334
Hub1 (lights across the bottom) or Hub2 (light in the centre)? See here for the  difference: https://www.plus.net/help/broadband/router-setup-guides/
It is possible PN have not been informed of the job completion, therefore have not changed things at their end.
The engineer is from Openreach, not Plusnet, by the way.
Fixes: 87
@andyfzr
This will help identify your router.
Unless the install was today where PN systems might need time to catch up you should get full speed almost immediately. There is no settling in period.
Did you order a Hub2 as part of the install?
andyfzr
Just my old hub 2. I've not heard anything from Plusnet. Only getting this now
8.60
Mbps download
6.48
Mbps upload
Latency: 8 ms
Server: London
Your Internet speed is fine.
Your Internet connection should be able to handle streaming an HD video. If multiple devices are streaming video at the same time, you may run into some congestion.
andyfzr
Circle blue light. I think it's b 2. I've had it for a couple of years now
Fixes: 334
OK . Which speed tester did you use, because that is a load of bull? Which socket on the Hub is the Ethernet cable from the ONTplugged into? Check both ends are fully seated.
andyfzr
It was only fitted this morning but I just thought it would be faster than my old one at least. Just tried broadband checker and getting 7mb now
I'll have to wait and see if it settles down. Thanks
Fixes: 334
Can you reply to message #9 please?
Even without the notification from PN, FTTP connections should work as expected once they are properly completed.
outcast
Aspiring Champion
Fixes: 19
@andyfzr
Perhaps try switching off the new ONT for say 30 seconds, and then switch it back on ?.
Have you removed the old RJ11 VDSL modem cable from the master phone socket ?
andyfzr
Just reset it all and getting 5.4 now. I'll have to contact Plusnet
Fixes: 87
@andyfzr
Login to your PN Members page and see if there are any Open Questions / Tickets on your account.
Fixes: 334
@andyfzr Are you plugged into the WAN port on the Hub, and exactly how are you testing, please?
