New FTTC Installation
- Full Fibre
- Re: New FTTC Installation
17-03-2011 10:23 AM
Morning all!!
I have recently been accepted on the fibre trials and i had the service installed on the 6th of March and everything was going great:
that was until 2 days ago when my speed dropped from 35mb down speed to 3mb down speed
Overall Plusnet have been very helpful and the tech staff I have spoken have been great but really wanting to get this sorted out.
Any comments or help will be greatly appreciated.
Cheers
Michael
Cheers
Michael
Message 1 of 5
(1,265 Views)
4 REPLIES 4
17-03-2011 3:16 PM
Could be: -
- Profile - PN tech probably checked this for you already, you should be on 20 or 37 in member centre / high speed broadband
- Line glitch - turn BT modem off/on and wait 3 days to see if the speed comes back
- Faulty modem - is the BT modem very hot? If so turn off, leave to cool, turn on, if this fixes it raise fault against the modem with PN
- Faulty line or cabinet equipment, only PN could determine this.
Message 2 of 5
(553 Views)
18-03-2011 10:38 AM
Have you power cycled the BT modem and your router?
Message 3 of 5
(553 Views)
18-03-2011 10:50 AM
@ Knowdice
Yeah have powered cycled the BT Modem and the router, speed picks up for a little while and then drops low again.
Cheers
Michael
Cheers
Michael
Message 4 of 5
(553 Views)
18-03-2011 11:05 AM
There do seem to have been several reports on here of faulty modems as jedi98 says how hot is yours?
Mine sits on the floor and with an ambient temperature of 18-20degC the top of the modem measures at 32degC - so just warm really.
So if you have a temperature issue then you probably need to raise a ticket and get the unit replaced.
Message 5 of 5
(553 Views)
