New Customer
tyga2025
Re: New Customer
Customers are wondering why are my speeds are flucating on full fibre connection ? dropping speeds etc .
Plusnet knows the answer as Why this is happening but will not give you the information. Techanical Support will not provide you with this information.
You will be shocked if you knew
Bella123
Re: New Customer
shock us then
tyga2025
Fluctuating Speeds why ?
Plusnet knows the answer but will not provide you with the information.
tyga2025
Re: Fluctuating Speeds why ?
You would be suprised if you knew.
I just switched my 500MB sevice over to them on Monday 31st March 2025 .
Now switching my service over to Aquiss
tyga2025
Re: New Customer
Openreach offered plusnet to opt out of DLM Profile but instead choosed to keep it.
I have it confirmed today ( Berlive me on good Authority ) that they are using DLM Profile on your Full Fibre Connection..
It is not needed on Full Fibre Connection.
This is why your speeds are fluctuating.
@tyga2025
Well go on then, enlighten us.
Fixes: 374
Re: New Customer
@tyga2025 DLM does  not work on FTTP, and in any case @Bella123 is not on it.
RobPN
Fixes: 14
@tyga2025
Perhaps you're just here to try and wind people up, but you seem to know nothing everything about how things work, so I assume you realise if you've terminated a fresh contract with PN to move to another provider you'll be receiving a hefty bill for doing so.
RealAleMadrid
Fixes: 68
Re: New Customer
@tyga2025 I don't know where this nonsense story has come from but the only element of truth in your posts in relation to DLM is ...
It is not needed on a Full Fibre Connection
That is correct it doesn't exist at all on FTTP.
Best of luck with your early termination charges.
Fixes: 374
Re: New Customer
@RobPN , @RealAleMadrid I think @tyga2025 was a little late with his/her 'April Fool' joke. 🤣
tyga2025
Re: New Customer
Plusnet uses DLM (Dynamic Line Management) on full fiber connections, even though it's a full fiber service, because they're still using the same Openreach infrastructure that was originally designed for copper-based services, and DLM is a mechanism to optimize performance on those lines.
tyga2025
tyga2025
Re: New Customer
Fixes: 374
Re: New Customer
@tyga2025 FF runs over completely different infrastructure - as you have been told previously - it does not touch the roadside cabs which contain the DLM mechanism.
Where are you getting your wholly erroneous information from?Huh
tyga2025
Re: New Customer
@jab1, Yes your correct in what your saying But not correct when we are talking about Plusnet.
If you do not want to belive that , Check with there IT
I know exactly what infrastructure should be in place when running FFTP Services.
Plusnet do not have that in place
Argue what you like but it is a fact
