National Lottery Website.
adamwalker
Fixes: 223
Re: National Lottery Website.
Hi all,
We're expecting this to be fixed today but please do shout up if anyone is still seeing the same issue.
 Adam Walker
buseng12
Seems to have started working again my end.
Anyone else want to check?
bobpullen
Fixes: 327
Yep, all good here Cool
whitehall
All good here too!!  Smiley
(gonna win it now tonight!!  Wink  )
nbk
Oh hey I went to check my numbers from last night and the site worked!
And I've won £3.60!
I'm rich!!!!
Err...
I don't suppose there's any info on what the problem actually was? Smiley
bobpullen
Fixes: 327
Quote from: nbk
The National Lottery have our IP's correctly geo-located in the UK but other (presumably recently introduced) network layer logic relies on whois data that sees these IP's as being registered to an address in the States.
I believe the solution was for the National Lottery to whitelist the range.
acarneiro
I've not been able to access it for years and my static IP address starts with 87
Seems to be working now, though. The only annoying thing is that I'd submitted a support ticket years ago with this problem and it just got ignored.
Oh, well. Better late than never, I guess... Smiley
special-dad
Hello, I can no longer access the National Lottery website. I complained to Camelot, but they have said that it is an issue with my ISP. This is their reply:-
Thank you for your email confirming your IP address.
I have checked the IP address and can see that PlusNet is the carrier for your Internet Service Provider. I can also confirm that PlusNet is connecting its service through a proxy that routes traffic from multiple countries and it is possible that you may be located in a different country from the IP location. Unfortunately as we cannot determine, without doubt, that that you are physically located in the UK or Isle of Man when using the IP Address 143.159.17.224 you will not be able to access your Account.…
spraxyt
Resting Legend
Fixes: 75
I wonder if the apparent presence of a proxy relates to being on the new network? Possibly @bobpullen could comment.
David
bobpullen
Fixes: 327
spraxyt wrote:
@I wonder if the apparent presence of a proxy relates to being on the new network? Possibly @bobpullen could comment.
No, it won't be anything to do with that.
The National Lottery use the geo-location provider Neustar to identify 'anonymizing proxies' and deny them access. It looks like your IP has ended up on this list, probably the result of somebody running a ToR exit node or something like that when assigned that IP.
I've a contact in Neustar who I'll ask to correct the categorisation, however in the mean time, you can probably get around the problem by disconnecting/reconnecting.
special-dad
Thanks Bob, I've re-booted about 10 times now. The way around for me is to switch Wi-Fi off on my phone and use my O2 account to log in. I do hope that Neustar can help out.
bobpullen
Fixes: 327
Neustar have confirmed that the IP is *not* listed as an anonymizer. I've asked them to clarify that the entire range is geo-located in the UK too but I suspect it is.
That would suggest the National Lottery have some additional measures in place at their side that are independent of Neustar's geo-location.
If you're still experiencing problems then we may need to try contacting them directly. If you're still in touch with them, then feel free to direct them to this forum thread (you don't need to be a Plusnet customer to register) Wink
