My connection keep dropping out
Jishi
My Plusnet was doing so well until this last week. Now it’s keep dropping out. How do I fix this?
3 REPLIES 3
Fixes: 246
Re: My connection keep dropping out
What is your perception of "dropping out"?
When you think it has "dropped out" exactly what do you see - a red light on the ONT?  No red light, then the connection has not dropped out, even if a device reports (incorrectly) "no internet connection".
Do you need to do anything for the "drop out" to cease ... or after the perception of a brief break, doe it all work fine without intervention?
A full description of your internal network set up would be helpful, especially if Ethernet over Power adapters are involved.
goldenfibre
Seasoned Pro
Fixes: 12
I thought Full Fibre is more reliable? Seem lots of Plusnet users complaint about Full Fibre lately issues with ONT box or Plusnet end?
RobPN
Fixes: 15
It is.
