Milton Keynes FTTP - Connection keeps cycling connect/disconnect....
- Full Fibre
- Milton Keynes FTTP - Connection keeps cycling conn...
05-03-2014 9:44 PM
Anyone else seeing this ( not sure if it's my equipment ) but for the past day or so my connection is up then down...anyone else ?
Si
Si
Message 1 of 3
(1,275 Views)
2 REPLIES 2
Re: Milton Keynes FTTP - Connection keeps cycling connect/disconnect....
05-03-2014 10:07 PM
Sorry but my fttp link has been stable, excluding DNS change away from Plusnet's servers last night.
What router are you using?
I've heard bad things about HomeHub5 which have an issue which causes reboots on the router.
Do you have a spare power supply to try out as this happened to me on my adsl modem a bit back and it was due to a flaky power adaptor.
Message 2 of 3
(508 Views)
05-03-2014 10:09 PM
False alarm, looks like Airport Extreme ( maybe 5 years old ) is having trouble with wireless.
Forget I said anything
Message 3 of 3
(508 Views)
- Full Fibre
