Migrating from FTTC to FTTP - any username change?
larkim
A full fibre installation is taking place today for me, I don't use the Plusnet router as I've got a Deco M4 which currently gets the internet connection via an old BT Openreach modem.
In the Deco I have my existing plusnet username and password.
I presume when the fibre is installed and the ONT is connected to the Deco's appropriate ethernet port, the username and password will be the same for the full fibre service as it is for the FTTC service?  Is that correct?
My better half is the "appropriate adult" at home whilst the installation is taking place, so if anything needs adjusting I'll have to talk her through remotely.  (Or the engineer can just unpack the Hub 2 that I did get delivered as a backup option I suppose so she can have a usable connection today until I get home!)
5 REPLIES 5
Fixes: 344
Re: Migrating from FTTC to FTTP - any username change?
Your credentials remain the same. The only thing that changes is the physical connection.
Fixes: 541
@larkim you should be able to just disconnect the Deco from the modem and connect it to the ONT. It should then work without any changes.
larkim
That's grand, thanks.  Feel better for having asked the question though.
I would have marked both replies as the fix too if I had had the chance.  Appreciate the rapid responses.
Will be intrigued to see what real world impact the faster connection really makes, as tbh I've never noticed any real lag on anything anyway which isn't explained by the local network speed rather than the WAN-side connection.
Though I guess my sons can expect their Steam downloads to be a touch faster 🙂
larkim
All done, nice and easy.
Phone line still works though, which surprises me.  Assume it will disappear shortly though.
Fixes: 541
There's a day or two delay for the phone line 'cease' to take effect. Even after that you may still get a dialtone, as the line is unlikely to be physically disconnected , just 'stopped'
