May I join the FTTC tial
- Full Fibre
- May I join the FTTC tial
29-10-2010 11:56 AM
Hi dave. My cabinet just been enabled for FTTC as of today so I would like to join the tial if I may. I have already raised a ticked to join the trial but was just wondering if you could give me the thumbs up to join? As I stated in my ticket any day or time is ok for the enginners visit so will you please book me in for the earliest please?
Thanks dave.
Re: May I join the FTTC tial
30-10-2010 12:13 PM
Placed the order this morning, just waiting on BT to confirm the appointment. Will reply back to the ticket when I get the confirmation.
Plusnet Technology
02-11-2010 9:03 PM
03-11-2010 1:24 PM
Plusnet Technology
03-11-2010 2:02 PM
Plusnet Technology
08-11-2010 1:02 AM
08-11-2010 12:37 PM
Plusnet Technology
08-11-2010 3:53 PM
23-11-2010 3:41 PM
sorry I missed your call. I can confirm that I have recieved the correct router which is the Netgear WNR 1000.
24-11-2010 5:26 PM
Plusnet Technology
12-01-2011 10:47 AM
Just thought I would post a quick update. The ADSL checker said I should recieve D/L speeds of around 34.5meg and U/L speeds of around 7.2 meg. Well after a few weeks on the trial my D/L speed is syncing at 25 - 26meg :(, but the U/L speed is usually syncing around 6.5meg so no problem there. Does my line profile need adjusting?
Thank Dave
12-01-2011 5:02 PM
If its just the ip profile and your sync rate is higher (say 34 for example) then you need to wait for the DLM to kick in, check your sync and profile herehttp://speedtester.bt.com/
Check on your account to see what your Plusnet profile is set to, I believe it should be 20000 (means its un-restricted).
Personally I think its likely to be your bras profile(ip profile-set by BT) being restricted by a low sync rate, however I'm new to this so could be wrong!
Someone please correct me if I am wrong!
13-01-2011 12:26 AM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
13-01-2011 6:29 PM
13-01-2011 7:21 PM
Quote from: WWWombat No-one can get the line statistics out of the VDSL2 modem yet, so we can't tell what the sync speed is - except for gleaning the data from the BT installation guys & their tools.
Well when the BT engineer installed my equipment he did indeed test my line and the results came up as D/L 40 meg and U/L 10 meg. So I should be getting more tham the ADSL checker says im entitle to, but i will settle for it none the less. Please get me sorted Dave! Thanks.
