Maxing out consistently at at 74mbs and should be 145
rmeilg
Hi, I am only getting half the speed I signed up for. Is there a way to report this without having to wait on the phone?
Many thanks in advance
Neil
4 REPLIES 4
Fixes: 524
Re: Maxing out consistently at at 74mbs and should be 145
Are you using the Plusnet supplied Hub 2 router or your own, in which case what make/ model ?
Are your speed tests using a wired connection ?
rmeilg
Hi, I am using the new router supplied (plusnet hub 2) and a wired connection. I get the same speed through wifi and wire.
Fixes: 524
In that case it sounds like it may be a provisioning fault. Try https://faults.plus.net ( you'll need to login ) , I belive that gives an option to report a fault on full fibre
willcutforth
Fixes: 113
Hey there @rmeilg
I hope you are ok and having a great week so far.
I can see you have since contacted us. Do you need me to do anything else at the moment?
 Will Cutforth
