Line speed just halved
Ashridge
Noticed my vdsl connection was running a bit slow so I checked my router and saw the speed has dropped from 80mb down / 20mb up to 30mb down and 5mb up. In the diagnostics it show the attainable speed is 30/5 and it used to be 80/20. Any chance somebody could check the line or make sure the port is not throttled.
6 REPLIES 6
Fixes: 1,662
Re: Line speed just halved
Thanks for your post @Ashridge
I'm sorry to see your speed has dropped. I've tested your line tonight and the tests are showing a couple of issues we'd need to arrange an Openreach engineer to investigate further and resolve.
Can you reply to the ticket I've logged on your account Here with when you'd be available for a visit?
If you can post back when you've responded, I'll make sure we book the engineer as soon as we can.
Ashridge
Thanks for the quick reply, I've updated the ticket.
Thanks.
Fixes: 1,662
No problem @Ashridge
I can see we've got you an engineer booked in and we've updated the ticket with the appointment details.
Let us know how it goes.
Ashridge
Engineer has just been an fixed it, was broken cable in the street box. Everything is now running at full speed. Many thanks for such a speedy resolution. I've updated the ticket.
Ashridge
Fixes: 1,662
Thanks for getting back to me @Ashridge
Excellent! I'm glad to see the engineer was able to identify and fix the fault to restore your speeds.
Feel free to let me know if you have further issues or there's anything else you'd need help with. Smiley
