Lag
sturob
Lag
im getting lag spikes in games and sometimes is unplayable
9 REPLIES 9
sturob
Re: Lag
this is when is half decent
adam945
Fixes: 113
Re: Lag
Hello @sturob
Thanks a lot for getting in touch and I'm really sorry to hear that you've been having issues with your service. I've tested the line this morning though and can't seem to find any underlying issues with the network. I'll pop a KBD test below which shows that sync speeds are within estimates, and the looks relatively stable. I've also had a look at something called an RRT, this shows me historical data on how the line has performed, it's showing a few errors on the line, but all in all, it's looking pretty good. It's definitely worth noting that the line is still within it's training period, so performance can, and is expected to fluctuate.
Going forward, for gaming, I'd always recommend using a wired connection, I've popped into the router and can see that all of your devices are currently connected wirelessly.
If the issues persist for another week or so, please let us know, as I said, the mean time between errors is looking pretty low at the minute, though this should improve over the next few days. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 60.0 Mbps
Upstream Speed 15.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Not Run - Unable to run
Cross Talk Not Detected
Estimated Line Length In Metres 458.5
Upstream Rate Assessment Low
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From09:00to15:30
Interference Location Other
Interference Observed In Days 10
Technology VDSL
DP Type Internal
Profile Name 0.128M-60M Downstream, Interleaving Low - 0.128M-15M Upstream, Error Protection Off
Time Stamp 2022-01-12T14:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 59.9 Mbps 59.9 Mbps 59.9 Mbps
Up Stream Line Rate 14.9 Mbps 14.9 Mbps 14.9 Mbps
Up Time 884.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 1.0 0.0
Radius
You'll see also from the KBD that the line is banded at 60Mbps, I've just raised a request to get this unbanded, which can take up to three working days. It's worth notice though that banding is usually a symptom of a possible issue, rather than the cause.
 Adam
 Plusnet Help Team - Leeds
sturob
Re: Lag
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2d1d17c52f2c0c0f8ffef4483807ce8da286e8bc
adam945
Fixes: 113
Re: Lag
Thanks for posting that @sturob
While high latency can be a symptom of an underlying issue on the line, it's important to acknowledge that these can also be caused by factors well beyond our control, such as the online gaming servers you're connected to.
It'd help a lot more if you'd have provided us with further info in terms of your setup, again, just to reiterate, I wouldn't recommend using a wireless connection for high refresh rate games, especially when playing online.
 Adam
sturob
Re: Lag
its wired to pc , used different cables to test still the same , its not the game im connected to its every game
sturob
Re: Lag
as for now its abit better but well see the main issues seem to be between 6-11 pm
Fixes: 1,662
Re: Lag
Thanks for getting back to us @sturob
How did things go last night, assuming you were gaming then?
YouKnowIThatGuy
Re: Lag
Are you blaming "lag" for your poor performance on an FPS game?
Could be a substandard graphics card causing your "lag" issues.
sturob
Re: Lag
im blaming lag yes because if u looked at my graph funny enough it lags when i get huge ping spike
so pc , x box , ps5 all have the same graphics issues aye
