LOS red light on ONT - Leyland
PDT
Hi
My broadband has dropped this evening. It seems that my router can’t get a connection. The LOS light is also on the ONT.
I’m on the phone to customer service now however generally I don’t get anywhere with FTTP connections.
Anyone suggest any solutions?
Thanks in advance!
6 REPLIES 6
Aspiring Hero
Fixes: 33
Re: LOS red light on ONT - Leyland
@PDT
If you have a newer style (all in one) ONT then there is a pin hole reset on the left hand side of the unit.
PDT
Thanks.
Plusnet advising it’s a major service outage in my area (on Openreachs network).
Should be fixed by 1800 tomorrow 😳
Browni
Aspiring Hero
Fixes: 59
If it's an MSO why is nothing showing on the service status page?
Aspiring Hero
Fixes: 33
@Browni
Something deep in the dark recess of my mind tells me this page is for PlusNet systems, not the OpenReach network.
If it's a FTTP network outage then there may be little information available to PlusNet as opposed to a normal copper system outage.
Browni
Aspiring Hero
Fixes: 59
There was enough information available to them to identify an MSO in the OP's area and an expected fix time!
PDT
Thanks all.
Service was restored this morning.
